Skip to Main Content
HCL Domino Ideas Portal
Welcome to the #dominoforever Product Ideas Forum! The place where you can submit product ideas and enhancement request. We encourage you to participate by voting on, commenting on, and creating new ideas. All new ideas will be evaluated by HCL Product Management & Engineering teams, and the next steps will be communicated. While not all submitted ideas will be executed upon, community feedback will play a key role in influencing which ideas are and when they will be implemented.
For more information on products and upcoming events around #dominoforever, please visit: HCL Domino Page
Status Needs Review
Workspace Leap
Created by Guest
Created on Mar 10, 2023
Set length limitation for Multi-Line Entry
For Single Line Entry, there is a character limitation that can be set in the properties. However for Multi-Line, it is not available.
Checking the "application.xml", it is set by default to 1000000. Need to be able to set or modify this value larger or smaller than the default without modifying the XML file.
Use Case:
A user uploads a 6MB PDF file, then encodes it to Base64 and assigns it to the multi-line entry. This causes an error due to limitation of characters.
Refer to the attached files:
  • Attach files
